enable bgp peer-group soft-in-reset
enable bgp peer-group peer-group-name {address-family [ipv4-unicast |ipv4-multicast |ipv6-unicast |ipv6-multicast |vpnv4]}soft-in-reset
Description
Enables the soft input reset feature.
Syntax Description
peer-group-name Specifies a peer group.
ipv4-unicast Specifies the IPv4 unicast address family.
ipv4-multicast Specifies an IPv4 multicast address family.
ipv6-unicast Specifies the IPv6 unicast address family.
ipv6-multicast Specifies an IPv6 multicast address family.
vpnv4 Specifies the VPNv4 address family for Layer 3 VPN support.
Default
Disabled.
If no address family is specified, IPv4 unicast is the default.
Usage Guidelines
Disabling the soft input reset feature can potentially limit the amount of system memory consumed by the RIB-in.
After you enter this command, the switch automatically disables and enables all neighbors in the peer group before the change takes effect.
This command applies to the current VR or VRF context.
If you do not specify an address family, this command applies to the IPv4 unicast address family. To apply this command to an address family other than the IPv4 unicast address family, you must specify the address family.
If the specified peer group contains IPv6 peers, it is an IPv6 peer group and you must specify an IPv6 address-family. When the specified peer group is an IPv6 peer group, this command defaults to IPv4 unicast if no address family is specified. This command fails if an IPv6 address family is specified for an IPv4 peer-group.
The following command enables the soft input reset feature:
enable bgp peer-group outer soft-in-reset
Support for IPv6 was added in ExtremeXOS 12.6 BGP.
Support for Layer 3 VPNs was added in ExtremeXOS 15.3.
Platform Availability
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the BGP feature, see the Switch Engine v33.1.1 Licensing Guide document.
